I tried to clean my headphones with a needle and damaged the sound
I tried to clean my headphones with a needle and damaged the sound , The headset turns on and connects to the phone, but there is no sound, only the right headset was damaged
Это хороший вопрос?
3 Комментариев
depending on exactly what you damaged and the make and model you may be able to fix it, there are numerus tutorials on ifixit and youtube on how to repair headphones.
из frey_code
@nataliebissaker how did you damage it? Where did tou stick this needle? Does the other side still work or nothing at all? Have you disassembled your headphones? What make and model are they? Did they work before this happened
из oldturkey03
There is a small hole near the silicone on the internet it says to clean it with a sewing needle if the sound is too weak, I must have hit something and the sound doesn't work at all but the headset does work, the other headset works smoothly. The model, jabra elite 75t
из natalie bissaker
