My display is not visible
When I switch on the TV it shows like a light Grey, how can I solve it
Это хороший вопрос?
Это хороший вопрос?
@javeeth786 first verify for us that your TV is a Sony KLV-32R412C. The light Grey screen only means that your backlight functions. If you have no video, you first have to make sure that you do not have any video output at all. Try every input source that your TV has. If it still does not have a video, it is possible that this is a mainboard issue or (worst case) a panel issue. Unplug your TV, remove the power cord. Then remove the back cover. Now take a look at t all the boards. Check for anything odd like burned, or missing component setrc. Post some clear, large pictures of all of your boards with your Question. That way we can see what you see and hopefully guide you further. Adding images to an existing question
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 59
@javeeth786 Can you upload some pictures/videos of the problem? Adding images to an existing question
из Andrew S
Red light blinks for 6 times
из Taphim Ahmed
