Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
Can I replace the base weight on a floor lamp?
The base weight of my Kendal Three Lamp floor lamp is falling apart. It appears to be concrete wrapped in plastic. It is making the lamp unstable. Can the weight be replaced? Where to buy one? Can I do it?
Это хороший вопрос?
Счет 2
2 Комментариев
Thanks. I'm working on this today. You can see that the base has holes in the concrete. Do they provide any benefit? Do I need to make allowance for that or just fill the space.
Also, do you think the concrete needs to be a bit higher than than the metal base, rather than just flush with the rim?
Rick
из
It can be repaired, you can buy a complete floor lamp chassis on the website, you can buy it on ebay, Amazon or oovov.com.
из
Добавить комментарий
4 Ответов
Выбранное решение
Thanks everyone for the tips. I'll let you know how it comes out.
Был ли этот ответ полезен?
Счет 0
Наиболее полезный ответ
I don't have any special insights into this, but my first thought was to just turn the lamp upside down and fill the base with plaster of paris. That should give it sufficient weight to be stable and it should stay in place reasonably well.
Only issue that comes to mind is that you may have to figure a way to make a channel for the electrical cord; of course you can always mold the cord into the plaster, but for future reparability I'd think you'd want to be able to remove the cord. Maybe put a sheet of saran wrap over the top then use a pencil to press a channel into the plaster before it sets? With the plastic wrap you should be able to remove the pencil once it's hardened.
I'll be interested to see what you come up with as a solution. Good luck with your repair!
Счет 3
@dadibrokeit @rickm15860 plaster of paris does not have enough weight. Ask me how I know that. Yes, fixed on of those torchiere lights with a broken base. Knock the old stuff out as much as you can. No reason to go all wild on it, just tap the loose stuff so it falls out. If all of it comes out, good. If not, good too.
Go to your local building supply store and get yourself some concrete repair mortar. Disassemble the light as much as you can, and turn it upside down. Take a look a the current base and see how the power cable is routed through that. The same goes for the center post mount. See how it is currently sitting in the base. It will help to see what this all looks like, so go ahead and post a few pictures of the base with your question.
Once you figured out how to route all of this, use some sort of material (cardboard, wood etc and create a form that goes with your base. Mix the mortar as instructed on the package and pour it in the base. Use a piece of wooden board to scrape the top so that it is level with the metal base. Again, we can explain this better when we see your base.
Not a complicated repair, just a bit of a PITA depending on what the current one looks like. Also, make sure that you do not spend more on material then a replacement light would cost :-)
Adding images to an existing question
Update (11/30/23)
@rickm15860 perfect!
No matter if you remove all of the old "concrete or just part of it. You need to protect the center as well as the cable run. Get an old round glass or even a plastic container with roughly the same diameter as the center of your lamp (just higher than the base). For the cable, run a piece of wooden board, not sure where you are but something like a piece of 1x4 would work. Place that from the round container to where the cable exits the base. Cut that the length of the cable run and again it has to be higher than the base. Now you could "pour" the concrete in there.
In your case I would remove the light itself since it looks like a rather tall lamp and not removing it would be pretty cumbersome, Not impossible of course. Also, it appears as if the current concrete extends slightly past the base. You could consider p;acing har dard cardboard ring on the inside of diameter of the base with just as much overhang as you current base. If you want to place something on the outside diameter of the base it has to be rigid since it may "fold over" otherwise. That would/could make your base wobbly.
I do hope that this makes sense since I can visualize it but not sure if my vision makes sense to you :-) Once you have it formed out, place another picture of what you have and before you pour the concrete. Then we can all double check for any issues that we may have overlooked up to that point.
Счет 2
2 Комментариев:
Ah, good call on the concrete repair. I was thinking about suggesting concrete, but that seemed like overkill when plaster of paris is cheap and readily available but yeah, I can see where it might not have the density needed.
из
Ready-mixed concrete with small aggregate (< ¼") is best. Take off the old metal base to use as your mould, make a wooden peg to seal the hole for the tube. Turn it upside down and use an old spray-can lid to form the wider-diameter bit for the securing nut & washers. Fix can to peg with tricky tape - it doesn't have to be pretty. Cut a cardboard strip to give you a bit of extra height, line the whole thing with cling-film, and pour in your concrete. Support it on a work bench somewhere cat-proof, and leave it 72 hours to set well, take it out (easiest to lift the metal base off your new concrete weight) , and fettle the bottom of the concrete with a bit of coarse sand-paper on a wooden block to get the rough bits off the concrete. Use double-sided tape to add three strips of bubble wrap to cushion it, Reassemble. Works a treat.
Thanks for the idea!
из
You can buy replacement weights online!
I share a general search link below, but search replacement weight for bottom of lamp.
Oddly i went to 2 lighting stores & hardware stores and was told there isn’t any way and trash a perfectly good working floor lamp. A year later i still had it in storage & the idea popped in my head to check if there are replacement weights cuz this must happen a lot ( our lamp weight cracked & crumbled just like yours).
I realize you probably have remedied by now but I share this about searching online because someone else may with same problem may find this page topic just as I did.
https://www.google.com/gasearch?q=reolac...
Счет 2
Добавьте свой ответ
RickM буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 18
За последние 7 дней: 75
За последние 30 дней: 358
За всё время: 7,535
