Frigidaire FFFH20F3WW upright freezer green flashing light and beep
Hi.
I bought this freezer used/reconditioned a year ago and it worked for a while but then the green light below the door started flashing and beeping.
I opened up the inside front evaporator panel to find the whole evaporator totally frozen. I unplugged and let the freezer defrost with the door open. A day or two later I put the cover back on and plugged it back in and it worked for a day or so and then the green light started flashing and beeping once again.
I have not used this freezer since but recently decided to attempt a diy diagnosis/repair job.
I first started with the magnet and the reed switch to cycle through the freezers 4 options. With a clamp multimeter I was getting similar amp draws for the first 3 options but then then the 4th option (evaporator fan motor) I got 0 amps as my reading.
Everything at the back of the freezer seems fine. There doesn't seem to be any leaks, the condensor fan spins (when in test mode), the condensor is warm and I can hear it, no obvious damage.
So I decided to check the evaporator fan at the front. In order to access this you need to pry off the cooling tower and unplug the fan. There is also a white lead that is attached to the same wiring harness. I believe this is the thermostat/temp sensor as one end sits up behind the cooling tower and the other attaches to the top of the evaporator. ( I do not know how to check whether this is working)
Using a 9v battery, I checked the fan. It works fine.
I am about to check the defrost heater by using a multimeter on the ohms option. This will tell me whether thats working.
I have read that a good check is to find out whether the defrost thermostat is working by checking its continuity, putting it in a freezer and having it open/close etc. BUT i can't find one anywhere. All the photos I found are of a small round cased object that can often look visually broken with the top broken open. Anyway, this freezer does not have one, that I can locate!! Am I blind?!
The only other thing that I can think might not be working is the potenitometer behind the single knob that turns from cold to coldest.
I am at a loss as to what else to try/check. I'm happy to buy some repair parts but does anyone have any advice as to what my issue is?
Thanks in advance.
Update (02/08/24)
Это хороший вопрос?
5 Комментариев
Defrost heater element read 56 ohms which would mean that it's still good
из Ad Hoc
word for word andfrustration level matched. im bench testing this board tonight. if i find a solution im will post
из josh denny
I have exactly the same issue with our Frigidaire Upright Freezer FFFH20F3WWO. Due to design deficiencies, the unit was not sealing very well and the evaporator coil got completely frozen. In the process the potentiometer got damaged and was broken inside. Did not turn on the freezer and the green light at the bottom of the freezer started flashing.
The technician (authorized by Electrolux) changed almost all the major parts ( Control Board, Evaporator Fan assembly, Insulation, etc) except for the Potentiometer. All other parts (compressor, condenser Fan) work. I have done some trouble shooting on my own and have come to a conclusion that it is the Potentiometer. I get no ohmic reading between the yellow and Orange leads. I am sourcing a new potentiometer and can let you know if that solved the problem. I am almost certain that it is the temperature control circuit that is supposed to trun the unit on Hope this helps
из Ameen Allidina
BTW, the defrost timer is within the control board as it turns the defrost heater and off. There is no external Defrost timer in the freezer that I could find either. Check the continuity of the Heater Element which has fuses at both ends. It is a 120VAC circuit from the AC Voltage Board with this control circuit Board. Hope that helps
из Ameen Allidina
@ameenallidina Good luck Ameen. I did buy a new potentiometer but it didn't work. If you live in Canada, I'd be happy to send you it!
из Ad Hoc
