Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
A button is not working
Hello,
After some time I wanted to play with my 3DS XL, but for some reason the A button is not working anymore. Everything else is working. I don't really understand how it happened since it was in its protective cover.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Have you tried taking it apart and cleaning the membrane with ipa ?
Update (12/20/23)
@alix25904 Nintendo 3DS XL Power Button Replacement it should be pretty simple if you follow the guide
Был ли этот ответ полезен?
Счет 2
4 Комментариев:
I haven't tried anything yet since I'm not comfortable with the idea of opening it without knowing what to do, but I'll try this and post an update, thank you !
из
I fix it has tear down guide use it so you don’t break the console
из
You might need a tri wing screwdriver
из
So here's my update : I took it apart, and I cleaned it but it seems like it's the motherboard that's faulty, so I guess I'll just bring it to a repairer. Thank you for your help !
из
Добавьте свой ответ
Alix буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 118
