someone shoved headphone jack inside my laptop
the headphone jack got stuck inside the case and I'm wondering if i can repair it
Это хороший вопрос?
Это хороший вопрос?
You can try open it, and try from inside with needle push out the rest from jack connector outside. Or you can replace the small board with jack connector. Actually you can replace only the jack socket when you have some soldering tools and skills. Or old school play with some Sharp tweezers and try to put out.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 35
2 Комментариев
Could you take a photo an add it to this post? Depending on how badly it's stuck, the solutions can vary.
из Moth
@pythonze it will be easier to assist you if we an see what you see. Post some pictures with your Question. Adding images to an existing question
из oldturkey03
