How to replace but also find battery contacts for my teddy ruxpin bear
Need new contacts in battery compartment
Это хороший вопрос?
Это хороший вопрос?
Hi Brian,
That may take a bit of ingenuity, but should definitely be doable.
Since those are just four standard AA batteries, the contacts are probably going to be reasonably standard. I would probably start by taking it apart and removing the contacts so we know what you're dealing with exactly. If you can do that and post some pictures of what you find, I'm pretty sure we can find something that'll work for you.
Adding images to an existing question - iFixit Repair Guide
Here's about the best picture I could find of the battery holder.
I'm betting you can pick up a battery holder from somewhere like Amazon or eBay where the contacts will be similar enough to work. Without more detail, this one here would be my best guess at something that might make a good substitute. You'll need to disassemble the contacts from the battery holder and transfer them to your Teddy Ruxpin. It may take a little soldering too, just as a guess.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 26
