Fat yellow non see through spot on tv screen
Is it possible to repair spot on led screen? Probably pressure damage.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
@antonspoper6499 big depends. We will have to see what this looks like. If the screen has broken LCD's/LEDs then it is not repairable but needs to be replaced. Post some images of what this looks like with your Question. That way we can see what you see Adding images to an existing question
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Just added a photo
из
@antonspoper6499 dang! That is your display. Looks like some bad LCD/LED This is a 75" screen, it'll cost you more than a new TV, if you can even get it. Double check your warranty and see if you can still get Samsung or the seller to help with that. Otherwise, try to getting used to seeing that spot.
If it is an NU model, Samsung did have issues with the panels on those.
из
Добавьте свой ответ
Antons Poperedens будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 47
