No green in picture
Magenta screen on all external, aerial inputs, no green in picrure
Это хороший вопрос?
Это хороший вопрос?
@gary42893 what have you checked. The very first thing you want to do is to use different video inputs. Make sure that you are using Coax and Component inputs as well. Change your HDMI cable if that is what you are using. See if using the different inputs had a different outcome. Next, we would need to see what your display shows you. It is possible that this is a panel issue but most likely it is a failed Gamma IC or a failed main board GPU. Adding images to an existing question
Был ли этот ответ полезен?
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 20
