New battery wear level 19% in a day!
I brougt a new battery for my laptop, it wear level in hwinfo was 0% the first day and only after 2 charges it is now 19.2% in just two days.
Should I return it and get a new one?
Это хороший вопрос?
Это хороший вопрос?
Did you calibrate the new battery after you installed it?
Fully charge the battery and then run the laptop until the battery level drops to 10% and then recharge it again to 90%. Do this twice and then check if it holds its charge better.
If still no good it may be a faulty battery.
Был ли этот ответ полезен?
The battery need calibration? How is that done? I tried charging the battery and draining twice. The Laptop last for 3-4 hours.
Was it an OEM battery or just a compatible one?
I would get a new one given the rate of discharge that occurred.
Check if it's a OEM battery.
If it is not then that will be why it keeps going flat, unless it's faulty.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 41
