The Fitbit Versa 3 is a smartwatch released on September 25th, 2020. It features a larger display and built-in GPS.
Вопросов 20 Показать все
Why does my replacement battery not charge?
I have now replaced the battery in my Versa 3 twice with an iFixIt product. Twice now I have followed the instructions and successfully insert the battery(s) and proceeded with the charging instructions. Both batteries have charged to 100% then they quickly drain to below 36% and when connected to recharge say the battery is too cold to charge. Is this something anyone has been able to remedy?
Это хороший вопрос?
Оценка 0
1 Комментарий:
It has powered on with 2 separate replacement batteries, but continues to drain quickly and slowly charges with a "cold battery" warning.
из
Добавить комментарий
Ответов (1)
Has the Versa 3 powered on? If it doesn't you may need to see if it is an internal issue.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
J Spence будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 85
