The Fitbit Versa 3 is a smartwatch released on September 25th, 2020. It features a larger display and built-in GPS.
Why does my replacement battery not charge?
I have now replaced the battery in my Versa 3 twice with an iFixIt product. Twice now I have followed the instructions and successfully insert the battery(s) and proceeded with the charging instructions. Both batteries have charged to 100% then they quickly drain to below 36% and when connected to recharge say the battery is too cold to charge. Is this something anyone has been able to remedy?
Это хороший вопрос?
Счет 0
1 Комментарий:
It has powered on with 2 separate replacement batteries, but continues to drain quickly and slowly charges with a "cold battery" warning.
из
Добавить комментарий
1 ответ
Has the Versa 3 powered on? If it doesn't you may need to see if it is an internal issue.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
J Spence буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 175
