Руководства по ремонту и поддержке оперативной памяти (ОЗУ), используемой в компьютерах.
Why is my new 16 GB DDR4 slowing down my PC?
Это хороший вопрос?
Счет 0
3 Комментариев
Hi @boostsocia39504,
What is the make and model number of the PC or the motherboard if a custom build?
What are the specifications of the new 16GB DDR4 ram module?
How much ram is already installed in the PC?
из
8gb already installed. HX432C16FB/16 Hyper
из
@boostsocia39504
Knowing the PC make and model will help to know its specs as per what amount of memory it supports etc
из
Добавить комментарий
2 Ответов
Выбранное решение
This could be cause of some major software errors
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
OR it's because he didn't enable XMP/DOCP Profile in the bios, most of the time you have to turn it on manually as it's not always automatically set. He also never gave any details about his configuration of how it's currently setup, he didn't state whether he was adding to a previous set of sticks or if it were new all together.
из
Hi,
I see the RAM you bought is rated DDR4-3200Mhz.
If you enter task manager (Press Ctrl+Shift+Esc) and navigate to the performance tab and click into the Memory section, what does it say? There should be a speed section and if its set to a low value, it will slow down your PC considerably (a screenshot would also be useful)
Счет 1
Добавьте свой ответ
Boost Social Media буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 416
