The steering wheel is heavy
Это хороший вопрос?
Hi @hgff
Check that the power steering fluid reservoir has the correct amount of fluid (type PSF-3) in it.
If it hasn't then check that the power steering pump and hoses are OK (no leaks).
If the fluid level is OK check that the power steering pump belt is OK.
If all the checks are OK then it may be a problem with the pump itself.
Here's an image showing where the reservoir is located in the engine bay and here's a video that shows the location of the pump and the belt etc.
(click on image)
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 48
2 Комментариев
Hi @hgff,
What is the year model of the vehicle?
из jayeff
2006/2007 سنة السيارة
из Hgff
