The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
Вопросов 20 Показать все
Why does it take my phone long time to full charge
Battery full charge takes long
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Good afternoon,
It appears that the A12 is capable of 15W charging as well as sporting a 5000mAh battery, while not slow by any means this combination is not the fastest at its best.
I would first ensure that you are using the stock charger, if you are using an aftermarket charger look on the documentation or the model info printed onto the block itself.
If it does not read 15W I would suggest replacing it.
If you ARE using the the stock charger and said charger is not malfunctioning / or degragated I would then look into the phone itself.
Start by reading up on this comment thread posted a while back ago, as you might want to try to clean out the port
If cleaning the port is not sufficient you might want to look into 1) replacing the port *i.e sub board or 2) replacing battery
I hope I was able to give some assistance.
I understand repairing a device can be over whelming, however there are plenty of people on iFixit that all love to leand a helping hand, please do not be afraid to ask for assistance.
-Lucas
Samsung Galaxy A12 Изображение
Инструкция
Samsung Galaxy A12 Disassembly
Сложность:
Легко
10 - 25 minutes
Samsung Galaxy A12 Battery Изображение
Инструкция
Samsung Galaxy A12 Battery Replacement
Сложность:
Легко
10 minutes
Был ли этот ответ полезен?
Оценка 1
I've had this problem a few times with my own phone, a Galaxy S8, and it has always been because the charging cable or the plug (or both) are not working correctly - or they aren't capable of providing fast charging. After replacing them my phone charges fast as normal. What condition is your charger in? Is it specifically a fast-charger? Do you get a message saying to check your charging connection?
Оценка 0
Добавьте свой ответ
Frank Fajad будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 105
