My pc keeps overheating on startup
It hasnt been like this in the first 2 months. But all of a sudden my pc whenever i turn it on, it starts normally and with no applications being opened or anything, the cpu temp just keeps rising untill it reaches 115 Celsius and then it shuts down. Usually i just turn it on, see its overheating, and turn it off and continue the cycle untill it decides to not overheat on startup. I turned of all of the startup applications and im sure that my coolers pump works. But it still keeps overheating.
My pc specs are:
4x16gb 3200mhz kingston ram
Nvidia 3060ti 8gb vram
Ryzen 7 5700x cpu
Asus b550 aorus elite motherboard
My power supply is asus bronze 750w
And cooling system is lc power lc-cc-240-LiCo
If anyone can help me fix this it would be amazing, thank you in advance.
Это хороший вопрос?
1 Комментарий
I checked the mounting and the thermalpaste, its all good and nothing is missing/lacking. Im not sure if there is a problem with something forcing the cpu to overheat itself. I checked the voltage and its 1.1 so its fine
из Petar Velickovic
