Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
White screen of death problem
Hello, I have a MacBook Pro 1278 2009. When you turn on the device, a white screen appears and nothing else. I've tried all the ideas. Command + R and Command + Alt + R. But all that appears is a folder with a question mark inside. I changed the hard disk cable as well, to no avail. I hope you can help
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@rayq2009 This "But all that appears is a folder with a question mark inside" means that your MacBook Pro does not find an OS. It's either a bad disk or the OS is not on it or corrupt. Check this post for resolution of this issue MacBook Folder With Question Mark
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
rayq2009 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 25
За всё время: 181
