MBP shuts down when charge hits 80%
I have a MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports) with function keys. Recently, the computer powers down when the battery power hits 80-ish% (really, it just shuts off). Have reset PRAM and SMC to no effect. I've also run the diagnostic program (i.e., hold D on restart) and the report came back clean/no issues.
Any ideas of what else to check OR what the problem might be?
Coconut Battery Info
Current charge: 4058 mAH
Full charge capacity: 4058 mAH
Design capacity: 4790 mAH
Manf Date: 2015-03-30
Cycle count: 281
macOS Battery status: Good
Battery temp: 97.4 *F
Charging with: 0 watts
Power adapter: Connected
Это хороший вопрос?
1 Комментарий
Replaced the battery and that fixed the problem. Thanks for the diagnosis Russell Repair Co.!
I did have one small scare - installed the battery and it wouldn't power the computer and I had a battery error. Turns out I didn't plug the ribbon cable into the motherboard far enough. Re-inserted and the problem was fixed.
из AdMan02
