Released in June 2014, this phone has an 8 megapixel camera, 2500mAh battery and a 5.3" 720x1280 screen.
How do I fix my charging point?
I'm not being able to charge my phone so how do I fix it,?
Это хороший вопрос?
Счет 0
2 Комментариев
This device is not charging
из
@poonamsing65077 try to give us more information. Things like what you have checked, what you have tried are as important as it is to tell us exactly which device you are referring to.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@chowtang the micro USB port is soldered to your board. You will have to disassemble your phone, desolder the old port and then resolder a new port. Replacement parts are readily available at many online stores. To replace the port and since iFixit does not yet have a guide for this, use something like like this video for the disassembly and this video for the repair.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Chowtang буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 178
