Is it possible to replace the part that holds the blade?
Is it possible to replace the part on my multi-tool that holds the blade on the tool? For whatever reason, the four tips that hold the blade on the tool have broken off and now the tool is not usable. Thank you for your advise on how I can get my tool repaired.
Это хороший вопрос?
Счет 0
1 Комментарий:
@kendesarmo what exact model is your Ridgid tool?
из
Добавить комментарий
2 Ответов
Yes, it is typically possible to replace the part that holds the blade on various tools and equipment such as knives, saws, razors, and other cutting implements. The specific process and feasibility depend on the design of the tool or equipment in question.
Был ли этот ответ полезен?
Счет 0
@kendesarmo it will help if you post some pictures of the part you are looking for. Going by your description it sounds like you are referring to the assembly output shaft spline shaft assembly, part number 303626002. Ridgid PB R8223404
Adding images to an existing question
Счет 0
Добавьте свой ответ
Ken DesArmo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 48
За всё время: 751
