coffee does not flow into the carafe
brewed coffee stays in the filter basket and does not flow into the carafe
Это хороший вопрос?
Это хороший вопрос?
I don't know this devices, I can only give some general advices:
I wish you success!
Был ли этот ответ полезен?
Hello ccoffee! It may be because your coffee maker is clogged, and is unable to send any coffee into the pot. You can use a piece of wire to clean, or you can, if possible, wash it out. I hope this fixed your problem! - Gilchrist Dean
thanks but no not the problem coffee maker is brand new and i have washed it out after each use only 3 times used
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 39
3 Комментариев
@ccoffee can you verify that your coffeemaker is a Cuisinart DCC-1200?
из oldturkey03
it is a dcc3200 cuisinart coffee maker.
из ccoffee
@ccoffee let's see if the ifixit coffeemaker Guru @vauweh has any ideas on this new machine.
из oldturkey03
