Samsung NP-R580-JBB2 laptop computer with 500 GB hard drive and 15.6" display released in October 2010.
My laptop Motherboard Heat
My samsung laptop switch off automatically and doesn't switch on until now and also it come another problem the motherboard heat a lot why?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
@themediaso47697 start with the overheating issue first. Disassemble your laptop, clean the air vents and the inside of you computer. Then check teh fan and consider replacing it. You also want to repaste the thermal paste on your processor since it is most likely no longer doing it's job.
Use this guide Samsung NP R580 JBB2 Cooling Fan Replacement for the fan and the heatsiink. To apply new thermal paste use this generic guide How to Apply Thermal Paste
Once cleaned, new fan and thermal paste applied, check your laptop and see if it comes on. It is possible that you may have thermal damage to either the CPU or other parts on your computer. You have to deal with cooling first, then troubleshoot for whatever does not work. Let us know what you find out.
Electronics Skills Изображение
Инструкция
Сложность:
Средне
5 - 20 minutes
Samsung NP R580 JBB2 Cooling Fan Изображение
Инструкция
Сложность:
Сложно
20 - 45 minutes
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
The Media Sound Rec. будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 42
