Error Code C000, help!
I have a Canon Pixma MG6620 printer that is giving the error code C000 anytime I attempt to print something. Can't find the issue, and could use some help.
Troubleshooting done so far:
Have taken off both side panels looking for any debris. Have also taken off paper tray and open the back panel looking for debris. Nothing found.
Reseated all ink cartridges, cleaned tray and contacts. Wiped down clear strip, checked to make sure tray moved without issue.
Hard reset the printer. Unplugged, waited 10 mins, plugged back in. Also tried resetting while holding power button before and after (a suggestion in another thread)
Reset all settings, reconnected wifi, checked for updates.
Went through all printer maintenance. Roller cleaning, bottom plate cleaning, etc. Paper feeds fine, but got same error code when I tried "Cleaning", and "Print head alignment"
I'm not sure what to check next. Everything looks clean/clear, but not sure what the issue is. If I can't get an answer here, my next step will be to just take the whole thing apart piece by piece and hope I find the problem.
The printer does make a sort of whirring noise that sounds like it made be motor or gear related. But paper feeds fine and print head moves fine.
Any help would be greatly appreciated. Thank you in advance!
Это хороший вопрос?
2 Комментариев
Reseated all ink cartridges, cleaned tray and contacts. Wiped down clear strip, checked to make sure tray moved without issue. Reset all settings, reconnected wifi, checked for updates.
из Asha Kanta Sharma
@nick do you have anything for the OP? It's AI (even a stylegan created profile image :-) against NI. Man against machine. Let's see if we can get the upper hand on here ;-)
из oldturkey03
