My purifer unable to fill water in its tank?...why?
Это хороший вопрос?
Это хороший вопрос?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 10
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. Adding images to an existing question
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
из oldturkey03
