GoTab Android Tablet Advice Needed
Hi all, I'm new to electronics repairing world,
I've purchased 10 x GoTab tablets for spares or repair but can't find a guide on your site. As I'm new are these all made in the same factory with different brands Are all android tablets basically the same under the cover?
Thanks for all help?
Update (04/21/24)
Also I'm after what should be done in the situation. Should I assume that a device that won't turn needs a new battery or check the battery with a multimeter. The items have I presume been in storage.
Это хороший вопрос?
Счет 0
1 Комментарий
I've also noticed that there are some Versus branded tablets. Also looking at the original advert it states you could make two good tablets from three as all parts are interchangeable and should take 15 minutes to make a working tablet
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
get a usb amp meter it will help determine if the tablets are charging
Был ли этот ответ полезен?
Счет 1
7 Комментариев:
Hi apologies for the question what sort of meter should I be looking for
из
Thanks for the suggestion
из
Have ordered the meter and will let you know when it's arrived
из
Hi the meter has arrived . What do I do with it now?
из
Показать ещё 2 комментариев
I've been made redundant in my day job and will wating to get a job I will have time to to fully learn how to get know how the USB meter works sand get the original tablets together.
Счет 0
Добавьте свой ответ
JimEssex буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 162
