Samsung TV very thin horizontal lines top and bottom of screen
Model number QN50Q60BAFXZA
Very thin colored lines at top of screen. The ones at the top are very close together and the bottom are spaced further apart. This just started. Also, TV is hard to turn on after being off for a few hours. AfterTV is on for a few hours, it turns on and off okay. TV Model # QN50Q60BAFXZ
Today ,TV started turning on and off by itself. There is a black image that starts at the upper right corner and when it gets towrd the center of the screen the TV would keep turning on and off. After a while this woud stop. The TV is still hard to turn on after a few hours down and the lines are at the top and bottom of the screen. I have tried to send a photo of the screen turning black.but have benn unsucessful. Thanks.
New image you can see the lines by the womans face.
Это хороший вопрос?
@nav65 post a couple of pictures which show what your display shows you. Also, verify that model number. It doesn't look like a Samsung model number
Adding images to an existing question
из oldturkey03
Model number QN50Q60BAFXZA. Lines at top of screen and almost at the bottom are very faint and multi colored. The is one thin line abouy 1/3 up from the bottom. I have tried all the ao called simple fixes. The lines are there when all devices( cable box,sound bar, dvd player) are disconnected. I dont think they will show up in a photo. My mistake with the TV nmodel nymber.
из NAV65
@nav65 Those lines are of the same origin as the error with your panel. They are caused by failing GATE drivers on the same driver boards.
из oldturkey03
