Victrola VTA-270B turntable not working
Victrola VTA-270B turntable not working, motor is not turning and not sure what size Belt it takes. What are the items I should test? All the other items work Great...BT, Radio, and CD.
Это хороший вопрос?
Счет 0
2 Комментариев:
@kneeboy When the record player part is turned on and the tone arm is put onto a record, does the motor get 12 volts? If you have any pictures or video to add, you can so it using the Adding images to an existing question guide.
из
When the tone arm is moved there is nothing
из
Добавить комментарий
