Why is my battery dying so fast
It goes from 100% to 0% within a minute, and refuses to on without being connected to a power supply
Это хороший вопрос?
Это хороший вопрос?
Hi Anderson, That sounds like a hardware issue with your battery. There are a couple of things that could be causing this:
Here's what you can do:
You can look for a replacement on iFixit.com or Amazon.com.
Был ли этот ответ полезен?
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value against the Full Charge Capacity value.
To work out the condition as a percentage, use the formula Full Charge capacity value x 100 ÷ Design Capacity value.
If it is <35% you may wish to consider replacing the battery.
What is the model number of the laptop as shown on the product information label on the bottom of the laptop?
Here is the service manual for a Vostro 5402 and a Vostro 5300, that may help.
Use the manual(s) to access the battery in your laptop so that you can verify the part number which is printed on the battery e.g. JK6Y6, H5CKD etc. Search online using the part number only, applicable to your battery, to find suppliers that suit you best.
If you do replace the battery, remember to responsibly dispose of the old battery. The environment will thank you for doing this. ;-)
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 20
