Specs: Intel Core i7-6660U, 8gb RAM, 256gb SSD.
How do I change a broken charging port
I just bought this one second hand "as is". It won't take a charge at all. So I opened it up and the plastic charging port is cracked.
Is it possible to fix it without having to solder it?Or do I have to replace the charging port? And how?
Or is it not worth it?
Thanks in advance!
Это хороший вопрос?
Счет 0
1 Комментарий:
@girrble let's see what you got going on there. Post some pictures of your charging port etc. with your question. That way we can see what you see. Adding images to an existing question
из
Добавить комментарий
1 ответ
the steps should be similar but still check the teardown for this lenovo
https://www.youtube.com/watch?v=x061z_Rj...
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Girr Ble буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 237
