click wheel unresponsive: can I replace with 4th gen wheel?
I have a dead nano 4th and an unresponsive click wheel on a 5th.
Resets doesn't work (as no clicks at all).
Q1) Do 4th and 5th have compatible click wheels? Can I try to replace?
Q2) Any 'tricks' I should try before attempting to replace? (heard about a 'credit card' trick?
Thanks
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
albidani gaibazzi , no, it does not fit. The click wheel of the 4th is larger than the 5th and not as far recessed. Try to turn the hold switch off and on a couple of times. If that does not make a difference, you will have to replace it with the right click wheel. iPod Nano 5th Generation Click Wheel Replacement Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
albidani gaibazzi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 914
