ffc ribbons attach to wifi module where?
removed the lcd and button ffc ribbons from wifi module and can not remember where on the wifi module they get re-connected.BOSE BUTTON And LCD DISPLAY FFC PATHWAY TO WIFI MODULE PHOTO
not sure I managed to upload photo.
photo shows one ffc cable going to front cover of unit for LCD display and the shorter one goes to the top of the unit for button operation.
my question however is WHERE they COME FROM, as this photo looks like they both originate from the same connector possibly on the wifi module. this photo does not show wifi module in its entirety for me to see though.
thanks for your help and I hope I am helping you better so you can help me. lol
Это хороший вопрос?
Счет 1
3 Комментариев:
@susieq45402 not quite sure which connector you are referring to on the WiFi module. Post some pictures of what you have going on there so we can see what you see. Also, you did check through the guides on here Bose SoundTouch 20
Adding images to an existing question
из
thanks oldturkey, hope i have managed to upload photo and explain better in my post. .
из
yes by the way checked out all other guides but once again none of them ever show a detailed close up of (what I believe is called the "wifi module" board) located at the top of the unit and which way up and what connector the 2 ffc cables go. i can take photos of MY actual unit and where I am at later on today.
из
Добавить комментарий
