Руководства по ремонту и поддержка для Huawei Mate 9 — смартфона на базе Android, выпущенного в ноябре 2016 года.
Battery Charging Status Abnormal
How do I resolve the issue where my battery does not charge above 60% and brings a notification like Battery Charging Status Abnormal...??
Tried replacing faulty battery still not resolved tried different chargers, nothing.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
@wangumwanza the only other obvious thing to try would be to replace the sub board (daughter board) and to check the ribbon cable going from the sub board to the main board. If after replacing those you still have the same issues, then you will be looking toward a board-level repair. Разборка Huawei Mate 9
If nothing else, take a look on here and see if that helps you after those two other things I would try first.
Был ли этот ответ полезен?
Счет 0
it's not the battery, it's a bug in the update of EMUI software. Huawei misleading users instead of fixing it.
Backup your phone first, then downgrade to previous version software. problem will be resolved 100%. do not let the phone update automatically
Счет 0
Добавьте свой ответ
Wangu Mwanza буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 26
За все время: 559
