Levoit Core 200S Smart Air Purifier is an air filtration device that cleans and deodorizes the air in a room. The device can be connected to the VeSync smart home application, and can be controlled with Amazon Alexa or Google home Assistant.
My fans stopped working and I want to fix it!
My Levoit 200 lights up and everything when plugged in. The user control all seems to work and the only thing not working is the fan. I’d like to replace the motor and see if that fixes it. Please help me with how to get started and where I can get the parts!
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi @gordonzhou
Here's a video that may help with the disassembly.
As for parts the only parts online seem to be filters.
If after disassembling it and you can get to the fan motor OK, check the windings with an Ohmmeter to see if there's continuity through the windings. If the motor is faulty sometimes the fan's make and model number is found somewhere on the fan itself. Search online using that information to hopefully find suppliers.
If the fan motor tests OK you may have to see if power is getting to the fan when required, by chasing the wiring back to the control board.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Gordon Zhou будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 20
За последние 30 дней: 74
За всё время: 393
