A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Why my PC not shut down completely?
when I done using my PC I will click shut down on the start menu,or press the power button on the PC,but when I shut down my PC,the PC just turn back on,or if I scheduled a time to turn the PC off,the PC still turn back on again,idk why
Is there any solution to turn this PC off completely? It's annoying me after turn this PC off at night
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
This could be due to a few different reasons but this is probably due to configurations with the fast boot option in the bios, uncheck this option to ensure the pc can shutdown without restarting its previous state.
Double check your alert wake up timers and/or check the wake on LAN settings as well but check your bios settings for the option I mentioned previously that will solve the autorestart, also you could try holding the power button for a force shut-off but check the fast boot option first and then if you have issues I will assist.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Thanks,the problem is fixed
из
Woot! Glad to help!
из
Добавьте свой ответ
Pour Water On A Rock буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 98
