Information and repair instructions for Hotpoint Refrigerator
fridge has condensation and will not get cold.
my fridge (not freezer) will not get cold enough to keep my food, and has excessive condensation. door doesn’t shut well
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @ruesteadman,
What is the model number of the refrigerator?
If the refrigerator door is not closing properly the compartment is not being sealed therefore condensation occurs as warmer moist outside air enters the compartment through the gaps between the door and the refrigerator compartment and also cold air is lost to the outside, hence the warmer temperatures inside.
Check that the door seals are OK i.e. not loose, twisted, broken etc. preventing the door from closing properly and also that the door hinges are set to allow the door to close properly i.e. door top and bottom is straight and parallel to the cabinet.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
rue steadman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 109
