Kenmore Elite HE3 — это стиральная машина от компании Kenmore. Она идентична модели Whirlpool Duet.
Changed pressure switch, keep getting error code
I posted this earlier and didn’t get any responses so I’m trying again. I started getting an error code and was told the pressure switch was probably bad so I just replaced it. Tried doing a cleaning cycle but I keep getting a SUD error. Looking for help so my wife doesn’t just run out and buy a new machine.
Это хороший вопрос?
Счет 0
2 Комментариев
Hi @mcap20026
What is the model number of the washer?
из Поделиться
110 47789701
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi MCap,
Looks like you're not the first person with this issue that's had the same problem, so I'd say the place to start would be with the other guys who went through it.
SOLVED: Why am I getting a SUD error message? - Kenmore Elite HE3 Washing Machine - iFixit
In some cases the pressure switch fixed the problem, but there were several other cures that were found by various methods.
Finally, there's a technician's manual on the device page that has troubleshooting steps you can try.
Duet-Aid_also-Kenmore-HE3.pdf - iFixit
Give that a look and try some of the solutions then come on back and let us know what you found. We find that we can usually learn something from both successes and failures, so be sure to update your question with the results.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks for the input. I can’t seem to find anyone who has had a problem where after a minute of running a SUD code will come up even though there isn’t any soap in it. I’m also still getting the F35 code after replacing the pressure switch. The tech guide looks like it’s for a dryer so I’m not sure if I can use it or not.
из Поделиться
@mcap20026 Ah crap, you are absolutely right; I didn't look past the title since it was on the washing machine device page. I've edited my answer to include the other manual from that page instead, which IS for a washer. Sorry, my bad.
из Поделиться
Добавьте свой ответ
MCap буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За все время: 254
