Apple’s new format for the 14 lineup features a 6.7-inch OLED—like the Pro Max—but the same features as the iPhone 14 with a dual camera setup and the Bionic A15 chip with a 5-core GPU.
Cellular Issue - unable to access cellular data
Water damaged, dried out by opening the back and front keeping in rice for 12 hours. Phone came back on. Old screen no display so put a new screen and the replacement works. Two Problems Cellular Issue (no bars no net) and Phone keeps restarting.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi,
It looks like water has affected the motherboard. iPhone 14 has a dual motherboard; the top board is for UI, and the bottom is for communications (network/cellular). Water ingress can affect the connecting layer and cause corrosion between the pins. This could be the reason why the iPhone is restarting and does not have cellular (baseband)
This is going to be a chip-level repair, and only a trained professional can perform such complex repairs. The boards will have to be separated, serviced, corroded parts replaced, and the boards reballed and refixed.
BR
Francis
CelMetro
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Arbin Shrestha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 33
За всё время: 284
