Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Lcd not working after rebuild
I plugged these 2 cables in the wrong place see picture turned it on screen dead nothing after taking the lcd off and realised what i had done connected cables correctly now lcd not working but will work ok with a external monitor thinking i had damaged the lcd  Temperature Sensor Cable i purchased another one of ebay but still not working does anybody have any idea what i have damaged main board or lcd or inverter board ?
Edit: close ups
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Clearly your action damaged the logic board in some way. I don’t think swapping the cables is the issue, instead I would check the displays data cable as it could damage the logic board if installed backwards and/or damage the socket getting pulled when pulling on the cables in trying to disconnect or even reconnecting the cables. If you had reversed the display cable often times this cap gets damaged
Let’s get a better image of your logic board of the displays LVDS connector to see how it looks, take some nice tight, clear and focused pics looking straight on slightly down and from the side, posting them here for us to see
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Added more pictures I’ve been into computers for over 35 years windows 3.1 then win 95 building fixing and helping people i won’t touch alienware pcs and i don’t think i will be touching another imac i upgraded this from a i5 to a i7 2600s re pasted added ssd and more memory it works ok with a external monitor purchased the OWC sensor cable but fans still on full
из
@davidmitch91997 - Mac’s are a different beast for sure!
While hard to tell as the images are hard to see the cable end does look like it lost its edge of one or two pins. The socket looks a bit distorted the far left/right detent sockets are bent up so the cable pins can’t secure it fully. These are easy to damaged and often if you bend them back they snap so don’t push it a piece of tape is about all you can do across the flat part of the connector.
For now, you’ll need to replace the cable if it’s indeed damaged. It should mirror the other side. This could explain why SMC is pushing the fans, after replacing the cable let’s see where you are. Here’s the needed part iMac 21.5" Display Port Cable
из
Добавьте свой ответ
David Mitchell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 120
