Chromebook C330 Boardview File
Hello All,
I can't seem to find a boardview file for bm5688 Chromebook C330 board. There is only a PDF format view. Does anyone know if there is such a boardview file out there? I cant believe there is not even one made to buy! How is one supposed to navigate the components on the board. Please advise if you have any info on this situation.
Это хороший вопрос?
Счет
0
Hi @roger36774
Have you seen this site?
из jayeff
Thanks Jayeff for the info, but I think the file is still a PDF for the boardview. I was hoping there was a Brd.bin for this board so I could use the Boardview software to locate components like with the Macbook Boards.
из Roger
@roger36774
Wouldn't a pdf viewer work? Most browsers open pdf files.
из jayeff
@roger36774 if they are avaiable then they are really hard to come by. Have not found ine yet. The issue with the PDF one is that it does not list any values, correct? It just lists the components? Have you actually checked the PDF against your motherboard to make sure it is the right version? what version is your board? The reason why I ask is because I do have BM5688 schematic, but not the boardview. I can't tell if it is the proper schematic for your computer.
из oldturkey03
