Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Reuse iMac camera on MacBooks
I have already figured out the pinout of the camera and soldered the wires to a USB connector. It works fine, with one caveat. If I connect it to a MacBook running in clamshell mode, the MacBook would not enable it, since it thinks it's a built-in camera, which of course makes sense.
Now, my question is, is there any way around it? I can think of two possible options:
  1. Change the USB descriptor of the camera, which I doubt is possible. But this would be a universal solution.
  2. Change the behavior on the macOS side not to disable the camera when the lid is closed. I did some preliminary search and didn't find any answers.
So I figured I'd ask this community and see if anyone has a good idea. Thanks.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Sorry I don’t see a way to do that, the camera’s ID is confusing the OS as it was never intended to run two FaceTime cameras at the same time from the same system.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Deling Ren буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 29
За всё время: 207
