The third generation Kia Rio debuted on March 1, 2011, at the Geneva Motor Show, again based on the Hyundai Accent.
Engine misfire and jerking
I’m having a issue with my 2015 Kia Rio 1.4L (GCC specs). Sometimes when I start the car, the ignition takes longer than usual, and when it finally starts, I hear this jerking sound from the engine if I shift into D or R. The RPM stays at zero, even if I try to accelerate or drive. I changed the spark plugs yesterday, but the problem’s still there. The engine even shuts off sometimes while I’m on the road. https://drive.google.com/file/d/1ub3aeZB...
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
You'll first want to get the car scanned or buy a code scanner for yourself like this. That said, I know from experience with these older Kias that predate the faulty Georgia factory engines CAN be better then the newer engines (but are prone to oil consumption). In the meantime, see if you can siphon some gas from the tank and make sure you do not have bad gas using a kit like this kit.
Look for a misfire code, and start there; that's what it was for me when I had to look at a Forte from this period with the 2L i4. The component that caused problems in the one I looked at was the ignition coil, but I would start by replacing all four spark plugs if you see misfire codes, as it's a cheaper repair than the ignition coils. Make sure you clear the code so it stays out of the OBD2 code history. Once you swap the spark plugs with the same issue, move one of the ignition coils to another cylinder to see if the code moves; if it does, you know it's the ignition coil.
If changing the isolated ignition coil does not help, you may want to change the remaining coils, as the others may be on their way out, and check to make sure the injectors are good. If the injectors are fine (or you decide to try before condemning the car) and EVERYTHING ELSE (including the coils) has been checked over, you may have a more serious issue, like a bad engine. That said, before condemning the engine/car (assuming you have done everything else, mainly gas check/spark plugs/fuel injectors/coils), do two things:
This is what the page should look like (Note this is an EXAMPLE; find the SM for your Rio and locate the info specific to yours):
That said, here's the specific data for yours.
  • Get a borescope camera like this and check for issues like scoring in the piston rings, and severe oil consumption.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
Hi Thanks for you Reply After this happened i've changed the Spark plugs, then it's started to engine stop in the middle of the road, and coils also bit weak do you think it could be the any mechanical issue since the rpm in zero ?Hi, thank you for your reply. After this issue occurred, I changed the spark plugs, but the engine started stalling in the middle of the road. The coils also seem to be a bit weak. Do you think there could be any mechanical issues since the RPM is at zero?
из
and i forgot to mention there's no engine check light or anything showing in the dashboard
из
@shaheer90269 I would try to replace the weak coils and have all 4 handy just in case especially if the gas isn’t bad. That said though most of the time it’s usually cheaper to try new injectors but as long as it ran fine prior they may be fine. When the Kia I mentioned had issues I did the plugs, then the injectors and neither helped, it was the coil (last thing I suspected given that one had Denso coils). However the injectors tend to be a heck of a lot cheaper.
из
I've scanned the car and found codes P0335 and P0620. The crankshaft sensor was the issue, so I replaced it with a used one. So far, there have been no problems. Thanks for your reply; I've learned a lot from you. @nick
из
Добавьте свой ответ
Shaheer будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 24
За последние 30 дней: 88
За всё время: 339
