Ведущий представитель iPhone 2020 года от компании Apple был выпущен 23 октября и поставляется с 6.1-дюймовым OLED-дисплеем, 12-мегапиксельной двойной камерой и доступен в 5 цветах. Преемник iPhone 11.
battery replacement gone wrong
so i just finished replacing my battery after watching youtube videos (i'm a beginner) and now my screen dosent show anything, i unplugged the connector for the new battery and connected the old battery and that one didn't turn anything on either.. keep in mind my phone was working fine other than a low battery health, can anyone tell me what this problem could be from?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Its sounds like you have damaged your screen during removal... easily done!
Был ли этот ответ полезен?
Счет 1
Most commonly an issue such as yours is related to either the connector on the motherboard or at the end of the screen's flex cable. If you're new to those delicate little plugs, it's pretty easy to damage them by pressing too hard or not getting the plug lined up exactly right before pressing the connector in place.
I'd suggest unplugging the display cable then check it carefully on both sides with a magnifying glass and a bright light. You'll be looking for bent or broken pins; bent ones can sometimes be straightened with fine tip tweezers, but missing pins will either mean replacing the connector on the motherboard or getting a new screen.
Assuming the pins all look straight and present, you'll want to clean both sides of the connector with 90% or higher concentration isopropyl (rubbing) alcohol, give it a minute to dry, then carefully reconnect the display. Pay attention to the comment at this point in the battery replacement guide:
Give that a try and let us know what happens.
Счет 1
Добавьте свой ответ
Tammy Allen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 109
