Repair guides and support for top and front loading Whirlpool brand washers.
Off Balance when spinning
Whirlpool LSQ7030LQ0 washer. Off balance when it spins. I have replace both sets of suspension pads, all 4 suspension springs and checked that the balance ring has fluid in it. What else can it be?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Does it do it if you spin it empty? If not, then it is the clothes distribution.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Yes. It does it empty. I just noticed that it is rubbing the bottom of the tub ring as it spins to the point that it is creating a bur on it.
из
There is a part, I have never replaced one but I have heard others replace them, under the tub. I can't remember what they called it. Could be a stem, seal and bearing. It isn't an easy replacement but it can be done. That would tilt the tub and cause your symptoms, I suppose.
из
Добавьте свой ответ
Randall Tipton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 108
