Lenovo Thinkpad P51 repairs, replacements, and teardowns announced in February 2017.
Вопросов 4 Показать все
Random shutdowns occuring under high load with new ifixit battery
I recently replaced the original battery, which was at around 45% health with a new ifixit battery. The ifixit battery has excellent battery life, however, I've discovered an issue whereby when under a high load when not plugged in, the laptop will randomly shutdown. It does not shutdown gracefully, simply switching to a black screen immediately. I've tested this on a number of relatively resource intensive games, with the same results. This does not occur with the old battery. Lenovo Vantage reports the battery as being in good condition so I'm at a loss as to what is causing this.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Hi @simonrooney
Try uninstalling the Microsoft ACPI Compliant Control Method battery drivers in Device Manager > Battery, and then when they have been uninstalled, close all open windows and restart the laptop in the normal manner.
During the following startup, Windows will reinstall the drivers. Check if the problem still occurs.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Hi @jayeff, that's solved the issue. Thank you very much :)
из
Добавьте свой ответ
C.B Gang будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 34
