Repair and disassembly information for Google's Pixel 7 Pro smartphone, released in October 2022. Identified by model number GP4BC and GE2AE.
Front screen replacement problems
Hey guys, have tried to replace the front screen twice now and everything is perfect until it comes to final placement of the screen.
Everything clicks and stick good except for the the lower right hand side of the screen.
This resulted in the first screen being damaged and the second one in the same problem.
There are no tabs out of place and everything is clean.
Could this be cause by a slightly swollen battery maybe?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Is your battery swollen? Have you tried a different parts supplier? Lastly, are you using the screen only repair or the one with the screen and frame?
Был ли этот ответ полезен?
Счет 0
Yikes, that’s a bummer! If the battery's swollen, it can mess with the screen fit. Better to address that first to avoid damaging another one!
Счет 0
Добавьте свой ответ
Tyson McDonald буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 90
