Nokia 5130 XpressMusic — один из мобильных телефонов серии XpressMusic компании Nokia. Он был выпущен в январе 2009 года и снят с производства в 2011 году.
remove the memory card password
I forget memory card password please help me
Это хороший вопрос?
Счет 18
Добавить комментарий
17 Ответов
Наиболее полезный ответ
Sreenu, try this "
Go to file manager on your phone
Go to settings and choose system folders,
In the System folder, find a file called mmcstore
Send the file to your PC using IR/Bluetooth
Open the file in Notepad
The password you need for your memory card is located within that file"
The other thing that might work for you is to "
1. Insert your card into your phone, without accessing it through the phone
2. Run FExplorer and Open the path C:\system
3. Find the file called mmcstore, and rename it mmcstore.txt
4. Copy that file (mmcstore.txt) to your PC and open it in Notepad
5. Your password will be located within that file. From here
One more thing you could try is to use a memory card read for your computer and format the cared through that. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 4
1 Комментарий:
there is nothing with the name of File manager or application manager in Nokia 5130
из Поделиться
Счет 3
i forgot my memory card password please help me remove
Счет 3
yes
Счет 3
nokia c5130 memory card not opned
Счет 1
how remove the forget passowrd
Update
how to remove the forget password of memory card
Update
tell me hoe remove password
Счет 1
how remove the password of memory cad forget
Счет 1
i forgot my memoey card password please help me remove
Счет 1
to know the password
Счет 1
hellp
Счет 1
i didnt know about system folder in my phone
Счет 1
Forget memory card password
Счет 1
how to unlock my password
Счет 1
Hello., i've tried this for my Vivaz U5i sony ericsson. use thirdparty file managers like Xplore or others that has an option to show you hidden files. then follow the steps of @oldturkey03 . never update Xplore because i can't see again mmcstore file after update. now i got 2 mmory cards cannot be used bcoz of password. my Vivaz has now a broken resistive touch. but anyways goodluck guys :)
Счет 0
Yes I forget my memory password
Счет 0
memory card password unlock
Update (09/12/2017)
my memory card password unlock
Счет 0
Remove tha memory card password
Счет 0
Добавьте свой ответ
Sreenu буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 35
За все время: 32,434
