Выпущены в сентябре 2020 года. Идентифицируются по номеру модели A3028.
Q30's won't turn on
Initially, the headset was switching itself off seconds after being switched on, during use.
Today, however, it didn't turn on anymore.
If I press the power button or the NC button, the blue light comes on. But it won't turn on.
When I plug in the charging cable, the red light comes on.
With the 3.5mm sound cable, the headset also works.
Does anyone know what might be happening and how I can solve it?
Service is not a possibility, because although the headphones are not yet a year old, I bought them through the official Anker website on Aliexpress and they refuse to provide repairs.
Это хороший вопрос?
Счет 2
2 Комментариев
How can I bypass the power button, in order to tell if that is the problem or a dead battery? I have a similar problem, but there's no light when the button is pressed, only when the headphones are connected to the charger
из
@tomasdiazaliste You can bypass the power board by using an AUX / 3.5 mm headphone cable.
из
Добавить комментарий
1 ответ
Выбранное решение
@ynae sounds like you may have a power issue going on here. It sounds like you're saying it is all working except that it has that power issue. I would consider starting with a new battery first. Check all the wiring and the power switch while you work on that. Use this guide Замена аккумулятора Anker Soundcore Life Q30 to work on it. Let us know what you find out.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Can you tell me where I can find the replacement battery? I'll try to follow the tutorial. Thanks for your help.
из
@ynae all of that will depend on where you are. I would wait until you have the old battery. Then use the numbers on that to do a search. That way you know you will get the right battery.
из
Добавьте свой ответ
Ynaê буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 26
За последние 30 дней: 106
За всё время: 2,027
