How to oper for accu replacement?
how to open the device? is there a central screw in the key board?
Update (03/10/25)
Type: HP Pavilion x360 Convertible, Model: 13-u167nz
Apparently there is a hidden central 9th screw in the center of the keyboard, which prevents me from liftig it to replace the battery. Or is it a clamp ore something similar?
Это хороший вопрос?
Оценка 0
2 Комментариев
Hi @wolfgangwe66244
What is the full model number and product number of the laptop, as shown on the product information label on the bottom of the laptop?
из
Добавить комментарий
Ответов (1)
Выбранное решение
Hi @wolfgangwe66244
There are 10 screws on the base enclosure that hold the keyboard/top cover in place.
Here's the maintenance and service guide, that is applicable to your model also.
Go to p.42 (50 of 94 pdf) in the manual to view the procedure to remove the battery.
Once you have the laptop open, just to ensure that you're getting the correct replacement battery and that it hasn't got the same part number (844203-850) for the battery as shown in the manual, locate the HP part number printed on the battery and then search online for the part number only, to find suppliers that suit you best.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Добавьте свой ответ
Wolfgang Weber будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 28
За последние 30 дней: 28
За всё время: 28
