Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
Apn number on battery
Hello everyone, I need help with my iPhone 3gs 16gb. the ios is 5.1.1. i replaced my battery and i found out that the battery is for iPhone 3g. I need help cuz i dont know what APN Number is on my old battery and i dont know what battery to order for it. my model number is.
A1303 and my FCC ID BCGA1303B IC ID 579C-A130B
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Brandon Kilgore, "with the iPhone 3GS the magical APN appears to be 616-0435.> Check on here for more
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
thank you so much. do you thank i messed up my iphone? i put the iphone 3g battery in and tryed to restore it before i new about the apn number and it gave me bunches of error codes. now that i know it was cuz of the battery. did i do any damage to the phone?
из
Not necessarily :-) see what you get when you have the new battery. The iPhone does give you all kinds of weird errors with the wrong battery, so you might just be okay.
из
i thought i bricked it. but i ordered 2 batterys and both of them are for the 3g and it did all the random shut downs. but it finally went to dfu mode with black screen. but last night i changed out the battery with the other one and it did turn on and went to the recovery mode screen with the usb and itunes so i thank that is a great sign. but thank you so much. i sent the people another email on ebay and im just waiting on them to reply back so i can get the right battery.
из
Sounds like your phone is still in good shape. Let us know how it is going when you have the right battery ;-), good luck.
из
Thank you for accepting my answer, good luck to you.
из
Добавьте свой ответ
Brandon Kilgore будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 5,141
