replacing battery, bottom logic board overheats
I have a ipod touch 4 that has a dead battery.
I tried to replace the battery and made sure that the contacts are not bridging... however once I solder the +, ground and negative contacts the board starts to get really hot! i immediately de-solder the battery.
Is the battery bad?
What would cause the board to heat up? thank you.
Это хороший вопрос?
1 Комментарий
Also I am able to power the device on via usb cable and it works fine.
из tony tony
